ls-vtec question?
brasilianstreet
well im almost finished with buying all my parts needed to build this beast but i was told to get gsr cams so i did but i want to know if i should get gsr cam gears also or aftermarket gsr cam gears or stay with Si cam gears ? also im setting my engine set up for turbo ?but turbo will be boguht after gota save first
gsr cams with stock gears are fine (there is no difference in gsr/b16 cam gears) and gsr cams work well with boosted motors too
