ls vtec setup
Discussion in 'Integra' started by fredsintegra, Jan 4, 2007.
  1. fredsintegra
    fredsintegra New Member
    yes could someone tell me what i could do for a fast ls vtec setup this is also going to be a daily driver. and using stock ls rods
  2. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    First there is no fast vtec setup, you have to take your time so you dont fuck up. First off go to goldeneagle.com and purchase the lsvtec kit. Then find yourself a gsr, b16, or itr head thats in good shape. Your still gonna want to mill it to be on the safe side. Then from what ive heard you have to change the oil pump and the water pump. The oil pump is for better flow up to the head since your going to need it for the vtec to work anyway and im not sure why about the water pump but if you have one that flows better then why not. Lastly, if you have not done this before dont make this your learning experience since its your dd.
  3. TREESnoseeds787
    TREESnoseeds787 New Member
    When you use the vtec oil and water pumps you have to run a GSR timing belt as well.
    The vtec water pump has 22 teeth versus the 18 teeth the LS has..
    Golden Eagle has one of the best and most complete kits out there. I'm building an LS/VTEC myself, I just ordered this kit and this is what my build consists of..
    GSR head
    Head has been milled
    Peak Performance Stage 2 cams and cam gears
    Skunk 2 valvetrain
    Skunk 2 intake manifold
    Accel 310cc injectors
    GSR water pump
    GSR oil pump
    GSR timing belt
    GSR distributor
    B18B1 bottem end
    PR3 pistons
    Shotpeened LS rods
    All ARP hardware
    ACL bearings
    In my opinion, to build a RELIABLE LS/VTEC then you must at least use ARP headstuds and rod bolts, ACL bearings, and it's a good idea to get the LS rods shotpeened to make them stronger. LS bottem ends do not like to rev high, your prolly gonna be making power 8000+ so your definently going to want to take your time, and do everything right so you don't spin a bearing or worse.
    Do some research, there are quite a few good LS/VTEC and B20/VTEC write ups on Honda-Tech.
  4. hazzardboy95
    Pasadena, Md
    There you go, listen to this guy. Hes done all the research.
