ls-vtec turbo headgasket
Discussion in 'Engine Building' started by tomtom, Jul 14, 2003.
  1. tomtom
    tomtom Senior Member
    central, cali
    what headgasket should i use 4 a ls-vtec turbo?
    i plan to make about 400hp
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    use the stock LS gasket.
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    yup, there are aslo aftermarket thicker headgaskets around also. Do a search and you should find them.
    Milan
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    indeed. stock or thicker aftermarket.
  5. deth101
    deth101 Senior Member
    usa
    just a note, the stock Honda gaskets are very well made and remember that if you go thicker you might change your compression a little
  6. JDMilan
    Boca Raton, FL
    I say oem hg.
    Milan
  7. tomtom
    central, cali
    has any of u guys made over 350hp with oem headgasket?
  8. deth101
    usa
    not personally but it's been done many times.........if you go aftermarket you dont have to go thicker Greddy[I think] makes stock size gaskets,thicker is not always better just more gasket area to fail,if you are really worried some people have O ringed 4 cyl's but it's a pretty involved process for really extreme use
  9. JDMilan
    Boca Raton, FL
    Since you have balls posting a post on how much we are posting on hp, post some Hp figures yourself, if your 81mm then stick wtih oem. if not then go larger, if you need a larger bore than do a search online.
    Milan
  10. tomtom
    central, cali
    dam bro
    didn t mean to hurt ur feelings
    i was just wondering if any of u guys did it ur self with an oem gasket thats all.
    but thanks 4 the info
  11. tomtom
    central, cali
    i went with the ls oem gasket
    thanks 4 th info guys
    i just got my arp head studs
    do i torq the it to 65 ft lbs or 70?
    4 ls-vtec
