LS/VTEC Turbo w/Tranny and all goodies FS
CoonAssTeg
Hello,
I have a LS/VTEC Turbo with LS tranny for sale: This engine is fully built, and was built to withstand up to 450hp+! I ran into some problems at the house and need the money badly. This motor was built 2months ago and it has just over 600miles on it now. It has yet to see more than 3psi of boost. It was tuned/broke in right after it was built so that the break-in period would be perfect. If you do purchase you will need to go get it tuned for boost. I have over $8300.00 in this build and didnt hold back. The only parts that are not new are a few bolts and the vtec solenoid. The block was completely rebuilt and the head was rebuilt with a three way vavle job and decked. Here is a parts list for you. This set up is made to make 350-375hp. :
1.Hondata S300with Boost control- $442.00
2.Turbonetics t3/t4 .50a/r $700.00
3.3bar map sensor $110.00
4.New Integra Radiator with slim fan $175.00
5.GSR Distributor $145.00
6.Silicone Couplings for piping $135.00
7.Greddy Turbo Timer $75.00
8.OBD2 to OBD1 harness $60.00
9.ARP headstuds $165.00
10. LS/Vtec Kit GE Kit $160.00
11. P28 ECU $165.00
12. Turbo Oil Lines $140.00
13. Spark Plugs and Wires $70.00
14. Cometic Head Gasket $150.00
15. Golden Eagle Block Guard $110.00
16. Golden Eagle Cam Seal $59.98
17. Honda B16a3 head $455.00
18. Wastegate Dump tube $37.99
19. GSR camshafts $175.00
20. STR cam gears $175.00
21. Boost, Oil temp etc..gauges $175.00
22. 2.5" custom Downpipe $200.00
23. AEM Wideband Uego $220.00
24. OmniPower Clutch Master Cylinder $125.00
25. Tial 38mm Wastegate $200.00
26. Golden Eagel Vacuum Block $30.00
27. PTE 680cc Injectors and Resistor Box $325.00
28. Ferrea Raccing Valve Seals $45.00
29. Supertech Bronze Valve Guides $85.00
30. Muetek Turbo Manifold $125.00
31. SRE Intercooler Piping $149.00
32. Emusa Intercooler $99.00
33. Walbro Fuel Pump $115.00
34. AEM Ruel Rail $110.00
35. Omni Power Valves $150.00
36. Sard Fuel Pressure Regulator $85.00
37. HKS SSQ BOV $130.00
38. AEBS Intake Manifold $180.00
39. ACT 4 Puck Clutch $295.00
40. Motor mounts Heavy Duty $100.00
41. Type R Oil Pump, Water Pump, ACL Bearings $280.00
42. SRP Pistons 9:0 $415.00
44. Eagle H-beam Rods $275.00
45. Tuning $420.00
46. bottom end assembly, bored out +.20, Balanced $1000.00
47. Port Job/polished on Head $350.00
48. Custom Oil Catch can $170.00
49. Carbon Fiber Spark Plug cover $65.00
50. Red Powder Coated Head Cover $75.00
http://i837.photobucket.com/albums/zz295/geauxsimon/DSC00419.jpg
I can send more pictures if you would like. just let me know.
ALSO I HAVE SOME 17" Gram Lights for sale with about 200miles on them;)
