Ls/Vtec, wat kind of ecu?
Discussion in 'HYBRID -> EG-EK / DC' started by doubleE, May 31, 2005.
  1. doubleE
    doubleE Junior Member
    okay, I'm running a LS/VTEC setup in my 94 integra. The Vtec head is a B16A Sir2 with stock internal and intake maniford, and the block is a 96 ls block with Eagle rods and b16a sir2 pistons. With this setup, what kind of ecu should i run? One of my friend told me that skunk p28 chipped ecu is not good. So, in this case, what should I do? any suggestion would help.. thankx..
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    get a socketed/chipped p28, and have it TUNED & rechipped.
    I got my socketed/chipped p28 for $150; cheap solution.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    agreed. p28, socketed and run uberdata.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :werd:
    The best would be one that is tuned to that motor.
  5. JayDeeEmDC4
    JayDeeEmDC4 Member
    I'm running a Socketed/Chipped OBDI P72 by ECUHacker.com
    Runs smooth...
    Bout' all I can say 'bout that....
  6. sohcslammer
    sohcslammer Senior Member
    Bay Area
    How the fuck did you pull that off? Eagle rods use a floating wrist pin and B16 pistons use a clip. I'd like to know how you got that one to work....
  7. doubleE
    Well, I don't know about that, but it worked. the machine shop took care of that for me. Anyway, since the head is basically stock, I planned to run a stock p30 is that okay? o one more question, can I run a ls throttle body with a b16a maniford? just wondering because my b16a throttle body is kind of bad.. Will there be any different in power? thankx..
  8. sohcslammer
    Bay Area
    The stock P30 WILL work, but I would still get some sort of tuning device. You should adjust your fuel map because you are not running a B16, it's a totaly different motor.
    I still want to know how your machine shop pulled off the wrist pin magic. I bought aftermarket rods for my CTR pistons and my machine shop told me there is no way to make it work. :shrug:
  9. JayDeeEmDC4
    JayDeeEmDC4 Member
    I am planning on building a second block for a later install(in bout a) month and I am also using SirII pistons with new rings, which rods do I have to get, I definitely want to upgrade though because my lsvtec right now is bone stock bottom and top and I want reliability and power.
    So all in all which rods fit which pistons fit which crank and so on and so forth...
