Ls/vtec - Why Can't I Use My B16 Head Bolts
Discussion in 'HYBRID -> EG-EK / DC' started by EGLsVtec93, May 19, 2003.
  1. EGLsVtec93
    EGLsVtec93 Junior Member
    Are they really too short or is this a rumor...if they are too short should I get GSR or ARP...how much can I get'em for?
  2. honda_mach3
    honda_mach3 Senior Member
    they are short, GSR and ARP are good. i would say around 20-30 bucks.
  3. EGLsVtec93
    i thought they were 100-150?
  4. honda_mach3
    if you could find it at a junk or used.
  5. Havok
    Havok Senior Member
    Florida
    Uhh, I don't think you should be using used head bolts, you have no idea what they have been through. Definitely get the ARP head bolts.
  6. hybridsol
    hybridsol Senior Member
    ohio
    never use used head studs, don't build and then cheap out in a very import part arps definaly
  7. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    They are really too short. Use the GSR ones from Honda or ARP.
  8. evcivic
    evcivic Junior Member
    arp head studs......... the best. golden!!!!!!
  9. chasengnouc
    chasengnouc Junior Member
    i am doing one right now and i am using orginal GSR head bolt. they are longer than b16a and when you torque it down it clamps harder on the head gasket to help is not leak oil sense the oil retrun holes don't line up. i bought the head bolts from Acura for about 10-12 buck a piece. if you can afford ARP go for it.
