Ls/vtec
Discussion in 'HYBRID -> EG-EK / DC' started by Civic EJ1 SiR, Feb 10, 2003.
  1. Civic EJ1 SiR
    Civic EJ1 SiR Junior Member
    New York City
    Anyhow i was originally looking into getting a GSR motor for my 93' ex coupe...but i have heard about the advantages to getting an LS VTEC instead..all i need to know is a the answers to these questions...
    1. Is this swap going to be cheaper than the GSR??
    2. What tranny should i use??
    3. Is this motor OK for turbo??
    4. Which head should i use??
    5. How can i make this motor rev as high as a VTEC motor??
    6. THe ecu should correspond with the head right??
    7. How reliable is this??
    8. How much should i expect to pay??
    9. What kind of HP and TQ numbers can i be lookng at??
    - I know that depends on the head so lets say..b18c or b16a JDM AND USDM
    Thanx for helping me out...peace...
  2. Civic EJ1 SiR
    New York City
    i also forgot to ask..where can i get these parts from....every website i goto only has complete swaps never just the block or the head separate...
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    No, unless you already have the LS engine this swap will cost you more than the GSR swap.
    For NA the Ideal tranny is a JDM ITR.
    Sure, I have seen several lsvtec's running boost successfully, but why? It costs a ton, it would be cheaper to boost a GSR or LS engine and you would get comprable results.
    Which ever head you can get for a reasonable price. There is no significant difference between heads. I think you will find it is easier to get a B16 head than any other.
    Install some ARP rod bolts on the LS rods and you are good to go for 8200 RPM.
    Any DOHC VTEC ECU from a B series works. I am running a P72, but you can run any ECU that matches you OBD version and came out of a DOHC VTEC car.
    As reliable as you build it. If you skimp and try to go cheap than I doubt this engine lasts you down the street. If you build it right it can be as solid if not more than a GSR swap.
    I started with an Integra LS (read I had the LS bottom end already) and mine cost me about $2500. Add the cost of the block and the cost of a tranny to that.
    There is really no way to predict this as each build is different, but I don't think that 200 hp at the flywheel is an unreal expectation.
    I bought a B16A1 long block and stripped it for parts for my build (pistons, head,...). Go to a junkyard and look for parts, try www.thepartstrader.com
  4. lsvtec
    One more thing, we have a great post in our FAQ about building this engine, check it out.
  5. cbrnascar0329
    cbrnascar0329 Banned
    www.thepartstrader.com :werd: :withstupid:
    found a b16 longblock on that site for 600....shop around it's not impossible to meet or beat that price....
  6. Civic EJ1 SiR
    New York City
    thanx for the help guys peace
