b16 head and an ls/vtec conversion. you will probably get flamed for spelling vtec wrong by the way maybe you can change it b4 anyone sees it. good luck i think golden eagle is a good brand for ls/vtec conversions
the basic things you need for your conversion is a vtec head, water pump, b series vtec ecu or a chipped p28 ecu.vtec oil pump the conversion kit, you will also need b16/gsr headbolts
yeah you you'll get a couple more ponies with the head. If you have the time and money i would put some pr3 pistons in there to raise the compression.
ohh and theres more to doing an lsvtec than you might think. read up on it here on the forums. i think B or someone, did a write up on how to do one. or at least explain the proper way of building one.
ITS MANDATORY you change the oil and water pump to at least a p30 or p72 one. you need the extra insurance for high revs. trust me i just lost my badass lsvtec build due to having the same old ls oil pump.
Go with a GSR head... and type R internals... look on ebay for some good parts... definitely go with OBX cams... stage 3 are the best cams made for hondas. Make sure you go with a type r oil pump too. You should do a little bit of head work as well. I just finished my LS/VTEC integra and I am running 14.0:1 compression and I am hoping to hit 12's at sea level. Let me know I am down to help you out
