Originally posted by SpodaB1@Mar 16 2004, 07:49 PM
To answer your question on which Water Pump will work, any B series will work, theoretically, however just use a B18B1 from Honda. Just use OEM B18B1 Water Pump becuase a VTEC water Pump may end up chewing the Belt to hell becuase a VTEC water Pump has less teeth than an LS pump does (it may have more im not sure). As said before you can go cheap, however it may cost more to fix later. So just uh go to honda and get an OEM part.
I can get OEM Honda parts at my mechanics cost, usually 20-60% off list price.
Good luck.
Brian
