ls wiring to 89 dx hatch
Discussion in 'HYBRID -> ED-EF / DA' started by StumpedLSswapper, Apr 7, 2004.
  1. StumpedLSswapper
    StumpedLSswapper Junior Member
    i am trying to find a way to wire my 89dx hatch to a 92 obd1 b18a1 i have the resistor box wired just need the other info thanx or wheree to find it
  2. brian11to1
    brian11to1 Senior Member
    run the motor as an OBD0 engien, you'll need:
    OBD-0 harness,
    OBD-0 dizzy,
    OBD-0 ECU
    I have the harness and will have the ECU soon. LEt me know
  3. javenger
    javenger Junior Member
    how do i know if the harness is odb0? is the o2 sensor on the exhaust mani one wire?
  4. brian11to1
    :postwhore:
    Now, the plugs should all be round, or circular in some way or another. nad yes the o2 wire that goes to the header is one wire. Ill get pictures.
  5. RSBAD454
    RSBAD454 Member
    OBD1 you dont use resistor box.........only Non OBD uses the resistor box. Non OBD connectors are a milky color, and OBD1 connectors are gray.....
  6. javenger
    where can i find a "HOW TO" wire up a dx harness to a b18a1 engine odb0?
