lsd install and bearings...
Discussion in 'General Tech and Maintenance' started by the_crazy_russian, Jul 21, 2005.
  1. the_crazy_russian
    the_crazy_russian Junior Member
    in an igloo drinkin Vodka watchin hockey!
    hi,
    before we get started, I did use the search engine and didn't come up with the info I was looking for. most of the posts were can I put tranny A into car B ect.....if I missed the info and it has already been posted I appolgise in advance.
    I'm installing an lsd in my z6 tranny along with some carbon coated syncros from gear speed. I was wondering what else I should replace while I'm in there. I'd rather make sure everything is good now, then have to do this again later. I have the tranny apart and the bearings that go on the differential will need replaced as they are a little rough. but what other bearings and seals would you replace? usually when people talk about rebuilding trannys they just say replace syncros bearings and seals but they don't say which ones...... I'm thinking I'll replace the speedo gear as well, that way I don't have to mess with the old one. so if some one could tell me which bearings and seals should be replaced it would be appriciated.
    thanks,
    B
    :worthy:
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    replace your rear main seal on teh block. Input shaft seal and bearing.and any seals or bearings in teh tranny.
  3. Taco15
    Tallahassee Fl
    whats the website where you found your carbon syncros? I'm looking for some for my B16 tranny
  4. the_crazy_russian
    I got them from GearSpeed on ebay. there is also some one who sells them on HT as well.
    B
  5. Taco15
    Tallahassee Fl
  6. B16CRX
    Greenville, SC
    I beleive gearspeed on HT offers teh 3-4-5 set for like $100 or $125. I have it saved in my instant message notepad on HT.
  7. phyregod
    phyregod !!YTINASNI
    Central Texas
    Get the final drive from an Si transmission.. install it! UBER d-trans!
    P.S. I have a si trans laying there... just... laying there..
    PSS.. NEVERFRIGGINMIND.. I was thinking you had a ZC trans. I have one of those too... ah hell, I need to quit whoring my d-series trans parts all over the place.
