LSD on ICE...
Sergey P.A.
Ok I was jest wondring, about the two differentials open and limited slip,
ok so the open one will send the power to the tire which has less torque,
and the limited slip will send equall amount of power to bouth of them,
so how will an LSD behave on ICE
is that still fun,
or not....
I don't know about fun... I hate the winter time and all weather associated with it. Why? Is it freezing in the 253? Goddamnit, I wanted to drive hard when I got home. :angry:
Anyhow, it will be much more controlled. The limited slip will keep you going in the direction you aim. The open differential has a tendency to throw the car to whatever side its tranction is being applied.
Oh, and for the record, you probably shouldn't take crystal meth while you are high on acid. It just wouldn't be safe. ;)
:withstupid:
I didn't have any problems with my LSD in the Civic when I was driving on ice and snow with Bridgestone S-03s on. Just be careful and the LSD will help you go where you need to go.
Sweet. That would be good to have up in Indiana...stupid Indiana.
dohch22a4
@ Dec 10 2003, 08:49 PM
:werd: :bo:
btw... Calesta, how much would an LSD cost for a Civic (Si)?
Dunno... anywhere from $300 on up to whatever you want to spend, depending on what you want to get.
Originally posted by Calesta+Dec 10 2003, 10:41 PM-->
revolution8k
Ah. There's an LSD out for the Escort GT 1.8 transmission... it's $1140 some. :eek:
How much did you spend on yours?
Originally posted by Tonyd0821@Dec 10 2003, 09:59 PM
this thread's title was VERY misleading..... :angry: :angry: :angry:
lol you druggie....
Anyhoo... the quaiffe is the best for the buck IMO. its like 850, but has a lifetime warranty as well
Originally posted by dohcvtec_accord@Dec 11 2003, 10:13 AM
A rear LSD, AWD and a turbo are VERY fun on ice.
:D
:angry:
Come take me for a ride sometime since I can't afford a WRX as my priorities have changed. :)
A Phantom Grip is an overpriced piece of poo. :)
And revolution8k, come out here for a visit, and you'll get all the ride-alongs and driving time you can shake a (losing) Mustang/Cavalier at. :D
Originally posted by Calesta@Dec 10 2003, 08:57 PM
:withstupid:
What brand LSD do you have in your civic? Was that for a SOHC or DOHC tranny though? I want one for my Si and I'm keeping her SOHC.
SWEEET!
where are you at anyway??
Originally posted by dohcvtec_accord@Dec 11 2003, 03:24 PM
Colorado y0.
:eek: :doh:
I'll be closer to CO in about a month and a half when I move to Texas. :D
It was in his old CRVTEC, which if I remember right, had a JDM ITR tranny. So then it just has the stock heilical LSD.
Stock LSD's are a nice entry LSD. They do burn out when you push large amounts of power through them though. The Quieff (quaiffe) is a very nice LSD for someone that wants something reliable. It is not the best LSD for 2 reasons. One, since it is a gear LSD, it produces more transmission lost then lets say a clutch style. Second, the quaiffe is more of a reactive LSD then a Proactive LSD. The quaiffe mainly only works when it detects slipage. Then it cuts power to that wheel and directs it to the other wheel, which in some cases can cause slippage with the other wheel. The Kaaz LSD on the other hand, the kaaz is a proactive because it prevents the slippage before it can occur. The problem is, The kaaz is a clutch style and just like your clutch, it can burn out over time. Also, It is not warreented, and I have seen many granade and totally destroy their transmission.
3 main types of LSD are:
Helical
Viscous
Clutch
if you get a factory LSD on a hydro B series tranny it will be helical
helical LSD's (quaife, peloquin, OEM Honda as stated above) are very nice because as long as both wheels are on the ground and have the tiniest bit of torque going to them both tires will be receiving power from the engine
if one of your front wheels gets off the ground then you are in the same boat as a guy with an open diff because they actually a torque biasing diff rather than a limited slip
Clutch diff's (Kaaz) are great if all you want to do are mad JDM burnouts or drag racing but will make your car more difficult to turn. the reason being is that when the clutch plates "lock" it forces both of your front wheels to turn at the same speed, which is fine on a straight away but when you are going around a corner the outside tire wants to go faster and the clutch diff will try to stop it making the car harder to turn (this won't happen with a helical lsd, therefore helicals are much better for road racing/auto-x)
viscous LSD's just blow (IMO) some 240's came with this type of lsd and it will work and be better than an open diff but I wouldn't pay any money for one of these. the way they work though is that there is a "fluid" in the diff that when it heats up due to the friction of the drive shafts turning at different speeds, becomes very thick (almost solid) and transfers some torque to the slower turning wheel
EDIT: what do you mean by "is that still fun?"
1500 for a new quaife center diff. for the GSX
sad i only have a center..i thought GSX had a front/rear one as well
OEM LSD. SOHC or DOHC tranny? I guess I'm lucky, since both my SOHC and DOHC both have LSDs in them. The SOHC is a clutch LSD, and the DOHC is a helical LSD. asmallsol, the transmission in the Civic is actually a JDM SiR2 transmission- the gearing is essentially the same as the USDM ITR, but it's JDM. Got it?
:lol:
Martine, if you want an LSD for your car, you can go aftermarket, or you can find the elusive JDM hydraulic S20 SOHC transmission for your car, or you can get something aftermarket like the Quaife.. which will also make your transmission pretty much bulletproof.
