I just swapped a H22A along with LSD tranny into my 95 lude. Engine started up nice with no complications. When it came to test driving it, I was able to get the car in gear but when i released the clutch, it sounds as if the gears are no engaging or something like that. I asked the shop where i got my swap at and he said to adjust the shift linkage. I checked out my shift linkage and do not where to look as far as adjusting anything. The only thing i found where i could adjust anything is the cable that shifts from left to right.
