Lsv issues
Discussion in 'ECU's, Electronics, and Tuning' started by Zmatt06, Jan 9, 2014.
  1. Zmatt06
    Zmatt06 New Member
    I build an lsv using a b18a1 bottom end an stock ls crank bored .50 over and a b16a head all stock internals with a p30 ecu....b4 the swap my vtec hit an it hit hard...after the swap my vtec does hit or kick in at all....im wondering if the p30 is my problem an need to switch to a p28. Im thinkin it might b in limp mode but i didnt think that would make my vtec completely stop workin...im at a loss of wats goin on or how to fix it any tips or ideas would help
  2. Briansol
    the p30 adds knock sensor control over p28... the ls blocks don't have knock sensors.
    So, you either need a map that disables the knock sensor on the p30, or revert to a p28. Either way, you should have a custom map/chip made on a dyno for your car as neither ecu is ideal to fuel an ls/v, especially one with larger combustion chambers form the bore.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Any engine codes?
    Knock Sensor could be an issue but I've seen guys rip up GSR swaps with no Knock Sensor without issues with performance.
    Limp mode often leaves no VTEC
    Oil pressure...oil level maybe
    VTEC Oil Pressure Switch?
    VSS/Speedo will cause this too.
    VTEC filter/screen dirty?
    Tach working?
    That's all I got right now.
  4. SPA Motorsports
    SPA Motorsports New Member
    i would double check all of your wires for the vtec solenoid...
