LSV "puff of smoke" during startup/ idle
Discussion in 'Integra' started by RauL8604, Sep 25, 2010.
  1. RauL8604
    RauL8604 New Member
    Warren, OH
    I had a valve job done to my b16a head, brand new valve seals, perfect valve adjustment. When I start in mornings I get a little smoke. When I let it sit and idle for over 10 min, then rev it a bit, I get a few puffs of rather noticeable smoke. I would say it is more blue than white. What is bad?
  2. Briansol
    blue = oil.
    could be the rings on the pistons, or any other kind of blow by happening through the pcv/etc system.
  3. RauL8604
    RauL8604 New Member
    Warren, OH
    when I did the LSV, I basically had absolutely no way to incorporate my PCV valve. On the b18b head it was plugged right in the top of the valve cover, and on the b16a it went down and into a black box on the back of the block. Would no PCV have anything to do with it?
  4. Briansol
    yup.
    get a catch-can.
  5. RauL8604
    RauL8604 New Member
    Warren, OH
    I've been doing some research on the catch can. In theory, couldn't I just put a barb on the back of the block where the knock sensor would normally go (drill it through), run a hose from there into a fuel filter, into my intake manifold, servicing the filter every couple thousand miles? I don't need my knock sensor, I am running Hondata S300.
  6. Briansol
    Thats basically what a catch can is... the thing is, its oil vapors that you need to catch. the filter won't do anything. Get a catch can and drain it every oil change give or take.
    http://www.theoldone.com/components/breather/
  7. RauL8604
    RauL8604 New Member
    Warren, OH
    I am going to run a trial period with the filter setup. If I notice less exhaust smoke, the catch can will be ordered and installed asap. Thanks B for your tips and knowledge!
