lsvtec almost done
Thanks, That must be some build! 11's in Colorado so 10's down here huh?
all i need to finish my lsvtec...
arp head studs
pickup the block
then , i can start with the machining and shit
cool shit y0. did you ever get those extended IM studs?
also did you put the ARP lube on the top threads of the studs? it looks like you didnt...
yeah i used the lube everywhere the only thing i did wrong was 70 ft lbs instead of 65. i ended up using regular bolts that worked pretty well.
