IntegralTendencies
just wanting some opinions on lsvtec build since I have kinda limited funds and need to make some important decisions on making the engine last as long as possible.....in aspects to the block I've heard many a suggestions on how to build it....I will be using p30 pistons on eagle rods with arp bolts as for the main bolts they will be arp also....is it intirely neccesary to have or a good idea to use b18c main caps and girdle or will the b18b's hold up and about balancing the bottom end better investment than rods and such or definant must have.....everything is going to be put together to factory specs and it will be a daily driver only revving to 7.5K or 8K max occasionaly.....your advice is great appreciated
