lsvtec need boring?
Discussion in 'Engine Building' started by Arachnid, Sep 13, 2004.
  1. Arachnid
    Arachnid Senior Member
    hi, i was wondering....if the ls (b18b g2) is in good shape would i still have to hone in the walls or can i just do a quick piston swap. i mean good shape as in...it still runs strong and has been leak down compression tested and still has close to stock compression and no leaks whatsoever. and no scars.
    i just need advice from people who's done this before.
    thanks
  2. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    I have never done it myself, but I have quite a few friends that swap pistons all the time and they at least do a quick little hone job before installing them.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Always hone your walls to make sure your new rings have something to wear in against and lubricate themselves with.
  4. Arachnid
    i wonder...would a little honing mess with my bore or would it be ok.
  5. phunky.buddha
    You should be fine. Send it out to a machine shop with the pistons and they can get it all lined up.
