lug bolt
MrTokai
anybody know how to replace a lug bolt on a 92 si h/b?
i stripped one out!! :imfucktard:
i looked at it and it looks like i have to take apart the assembly and get the hub/spindle pressed out to do it... if that's the easiest way i'll just take it to a mechanic... but if you guys know an easier way please, do tell!!
If it is on the front you will need a press to press out the hub and remove/install the new lug bolt. On the rear you can do it yourself. Remove the wheel. Remove the hub dust cap. Remove the nut either with an impact, a friend stepping on the brakes or putting the stock steelie on and lowing the car to the ground. Once the nut is off you should be able to pull the hub out.
