m3 mirror wiring
mainstang
does anyone know how to wire a pair of m3 mirrors into factory power mirrors. The m3 mirrors have yellow, green, and white wires. Factory has blue/white, blue/black, and some other color. Any help as to what colors match with each other would be greatly appreciated.
Did the mirrors not come with a wiring sheet?... Guess not.
Use a multimeter and test for continuity between any of the wires.
Then put a low amp fuse (5A) on all the wires... then take a 12 volt battand work thru the wires to see what does what... switch them around and try diff combinations..... the fuses are important so you don't blow up anything.
.... But don't yell at me if you do^_^
"Look it up before you Hook it up!"
