Im trying to make a part that has the same spline as a 87 or 88 crx clutch plate. i believe it is a 20 tooth spline, 7/8 diameter. im looking for technical data on this spline. can anyone help or point me in the right direction. thanks.
thanks ez,
i know its definately a 20 tooth. im trying to cut the splines, so i need major diameter, minor dia., pitch dia., engagement angle, chord length....and probobly something else.
no,,,theres some dimensions on it that are difficult to measure....thats assuming im measuring the right things. the major and minor are no problem, but the pitch and cord are the ones im not sure of.
I have a machine design book that I will pull out tonight and see if I can figure anything out. I'm not even sure if a FSM (factory service manual) can help you out there, worth checking though. Involute splines generally have a 30º pressure angle, nothing for sure yet.
