Made the Climate Control Swap (EG>EF) lighting won't work
Periculum
Hey guys, I've swapped my climate control out of my 91 CRX HF and put in one out of a 92 civic HB. Everything works properly except the lighting behind the little cartoons that tell me what areas the AC should be refreshing at the moment and behind the Hot/Cold color. My after hours mechanic took a look at it earlier tonight and resolved that all the wires are getting an appropriate signal.
The previous climate control slowly lost all the lights until the only thing that lit up were the button indicators. This is the same exact condition the new CC is in. I'll try to be checking the bulbs and voltage tomorrow. I hear this is a common problem with this swap and my search skills have come up short trying to find out any info on how to fix it.
As always, thanks in advance for your time!
