Will the GSR main girdle fit for use of a B18B1 block?, setup is a lsvtec. Instead of spending 450 some dollars on the GE main girdle set with the arp main studs I can get the gsr windage tray,oil pickup,and gsr oil pan at my work since i work at autoway honda for really cheap.
I just want to know if it will fit and line up correctly on the ls crank main caps etc..
