main relay not kicking fuel pump on
Discussion in 'Civic and CRX - EF' started by ALLORNOTHING, Dec 24, 2012.
  1. ALLORNOTHING
    ALLORNOTHING New Member
    i just bought a new main relay (fuel pump relay) i put it in n my car still wont start oh yea its a 91 crx anyone got any thoughts
  2. dc4dude
    dc4dude Member
    chicago, il
    Are you getting power to the fuel pump? What about ground? Is there power at the fuse? Is there power to the fuse block? What other diagnosing have you done besides replacing the main relay? Is there power at the main relay with the key on/ engine off?
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Did you check the fuse?
  4. ALLORNOTHING
    all fuses r gud. wen i turn the key onthe check eng lite stays on n i am getting power to the fuse block
  5. civicious
    Houston, TX
    Try swapping out the 'gud' fuses for 'good' fuses, see if that works
    Are you saying that the car won't CRANK or won't START?
  6. Jeef
    Jeef NO MA'AM Moderator VIP
    I am surprised you can read all the incomplete words. If he can't even type complete words, he will probably be too lazy to change the gud to a good fuse.
  7. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Check engine light should shut off after a few seconds.....at least all the ECU's I've had do this. Might have to pull codes and see what's up.
    As it applies to grammar......texting/laziness/false sense of entitlement has jacked many of our youth up. If it can't be done fast.....it ain't worth it lol
