Main relay prob?
Discussion in 'HYBRID -> ED-EF / DA' started by CrazyAzn, Jun 18, 2005.
  1. CrazyAzn
    CrazyAzn Senior Member
    well the topic is basically what is stated above, my car cranks over and there is spark, i noe this because is shocked the shit out of me. (hurts very much by the way) this problem just recently started with my car, i am running a d16y8 in an 90 hatch. the car was running fine untill just recently when it started having problems starting. i noticed that when i turn the car on to the start position, there is no hummmmm of the fuel pump priming hte system as it usually did.
    its throwing no codes or any thing of the sort.
    pm6 ecu
    d16y8
    90 hatchback si
    si dizzy
    what controls the fuel system on startup? i cant find a fuse for it, so could it be the main relay? or is my fuel pump its self bad. or what else controls the fuel system. . . . . someone please help
    i am completely lost as to what to do
    thanks guys,
    kyle
  2. JDM-ED7
    JDM-ED7 Junior Member
    I had the same problem on one of my hatchies and its most likely the main fuel relay that is behind the lever you pull to open the hood its a small black little box with redish brownish on it. and if that doesnt work its your fuel pump. I you have had problems before when starting it its your fuel pump.
  3. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    Get a multimeter and check the voltage at the harness going to the pump. If there is voltage when you turn your key to the on position the pump is probably bad. You can usually access the harness by pullng up the back seat, or if its a crx by pulling up the glove box.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    Definitely a very good chance that it's your main relay... pull it and open it up to see if anything's cracked inside.
  5. tayhas
    tayhas Junior Member
    DALLAS
    9 out of 10 times this will be the main relay, the main relay controls the fuel pump and fuel inj. it is a 7-pin mitsuba rz-0063 it is a black case under the dash.
    they mostly stop when it is hot outside, but when it cools down it will start.
    tayhas
  6. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    ^^Yep, I had the same problem. My car wouldn't start when it was hot outside, so I got a new main relay off ebay for $15 and boom, works perfectly now :)
  7. Som1Dies2Nite
    Som1Dies2Nite Member
    I got the same problem on my brothers DX converted to Mini-Me. If I jump the Yel/White and Yel/Blk the car starts right up on the main relay. So would my problem be with the relay?
  8. CoreyR
    CoreyR Senior Member
    mother f. we just pulled the tank out of a 90 teg cause i thought the pump went bad cause we stopped getting gas, we pulled the pump and bench tested it and it worked, and i have no power at the harness for the pump under the rear seat. im guessing i could have saved a few hours and just changed the relay huh. looks like i know what i gotta do tomorrow
  9. g24jr
    g24jr Member
    MCMINNVILLE, OR
    PULLING UP THE GLOVE BOX???
  10. CrazyAzn
    lol, fuk we dropped the tank on my ef, but oh wells at least i have a new pump and main relay. coulda saved a couple hours n the hot sun. haha live and learn. . . .
    thanks guys
