maintenance required light??
Discussion in 'General Tech and Maintenance' started by 90crxb18, Jun 27, 2005.
  1. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    anyone know how to make the "maintenance required" light, on a 95 integra stop flashing everytime i start my car???
  2. E_SolSi
    welp first off that light is telling you you to get an oil change (goes off every 7500 miles i believe)
    anyway to turn it off on an integra:
    look under the driverside dash kinda close to the center console
    you will see a little button ( i think its blue )
    with the key in the off position, press and hold the button
    turn the key to the on position, dont start the car, still holding the button
    after a few seconds, the maitenence light will blink a few times and then turn off
    release the button turn the key off then start the car
    the light should be off
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
  4. 90crxb18
    lake elsinore cali
    cool thanks guys. that light has been bugging me for about a week, i just changed my oil about 500 miles ago so the light had to have come on from the previous owners last oil change....again thanks guys
  5. hybrid89
    hybrid89 thistownsucks...
    SoCal
    Would this be the same for say my 04 TSX. I have the same light and only if I take it to Acura is it ever reset?
  6. E_SolSi
    for the 04 TSX you will not have that button under the dash
    there should be a button to reset your tripometer (says "reset" on it)
    press and hold that button
    turn key to on
    wait for light to blink then turn off
    release button
    turn car off and restart it
    should be gone
    some require you to hold 2 buttons on the center dash area ("SELECT" and "RESET") ... not 100% sure on the TSX
    it should tell you how to reset the light in the owners manual
  7. CRX-YEM
    Wallingford, CT
    I asked this question about a month ago, I had to call Bill to find out haw to do it.
  8. E_SolSi
    sorry dennis didnt see your post
  9. hybrid89
    SoCal
    Thnaks E sol, too lazy to dig up the owners manual!
