Major Help In Tuning
Discussion in 'General Tech and Maintenance' started by SIGALPHGIO, Mar 17, 2003.
  1. SIGALPHGIO
    SIGALPHGIO Junior Member
    Ok Guys .......I desperatly need assistance.
    my 93 Del Sol
    D15B7
    5 speed
    i just installed that motor, and have 2 problems
    it idles at 3-4k and drops to like 1k and just keeps reving up and down. Could it be vacuum????? Ground???
    there is no alternator in the car......
    also . it is leaking coolant from the second hose from the left of the intake manifold ...I've tightend it..and it still leaks, where should the hoses from behind the intake manifold(behind throttle body ,close to firewall) maybe I have it backwards
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    it sounds like you have a lot of work to go before you should even be thinking of starting the car and seeing how it idles
    sounds like a huge vacuum leak. your iac valve hooked up? any codes? picture of that hose could help.
  3. pills_PMD
    New Albany, OH
    wait... did i also just read that you have no alternator in the car?
    i think you should probably hook that bad boy up as well.
  4. stud4u2c17
    stud4u2c17 Senior Member
    I had the same exact idle problem with my REX HF, it would stay at 2k till it got warmed up , then dropped to 1k and kept revving up... this is what i did to fix it, everyone told me it was a vaccum leak but i check and it wasnt... so i took the censor out of the back of the throttle body and started it up and it ran fine, my censor was bad, my check engine light is on and it will be till i get a new sensor but it doesnt idle funny anymore, check that and get back with me if you need any help.. lata man
    TJ
