MAJOR PROBLEM WITH 89 CRX si
Discussion in 'General Tech and Maintenance' started by shithatch, Oct 19, 2004.
  1. shithatch
    shithatch Junior Member
    Urbana, Ohio
    Alright my friend was workin on his crx ... doin some stuff with his cd player and all of a sudden his car started losin battery power and shut off. Now when we try to start it it just clicks over.. and makes A LOT of clicks comin from under the dash. I found the clicks coming from a little black box that says RELAY ASS'Y MAIN 12v. The starter also clicks. Does anyone have any idea wat the hell is goin wrong???
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Short in the electrical system, maybe bad main relay, definitely low battery.
  3. shithatch
    Urbana, Ohio
    He was messin with his cd player at the time it started doing it. It is rigged up because the wiring harness has been cut. The + and - on his amp might have touched together? could this have caused the relay to go bad!@!@??
  4. shithatch
    Urbana, Ohio
    Could the starter be bad!!!????
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    put a batt charger on the car and pull his stereo fuse then sey if it works
