Make interior quiet
Discussion in 'Body / Exterior / Interior / Cosmetics' started by lohonda, Sep 12, 2008.
  1. lohonda
    lohonda Member
    Hey I have a 92 civic hatch dx and the inside is pretty loud. I mean there is alot of road noise. Is there anything I can do to make it quieter?
  2. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    yea go buy some dynamat from a audio shop they use it for road noise and to keep stuff from rattling its the same concept or you can go to a auto store and buy the same stuff but a cheaper version. dynamat= 100 dollars auto store= 40 dollars its up to how good of quality you want.
  3. lohonda
    lohonda Member
    Where is the best place to put it? Like below the dash across the firewall? How much can I expect it to help? Thanks.
  4. eg6sir
    now, plan on your car being heavier after Dynamating the car
  5. newb
    newb phresh VIP
    Backwoods Northwest
    Put it where ever you can. Under carpet, under plastic panels, where ever. Just keep it away from heat sources, and be careful around wires.
  6. George777
    George777 ^^ Likes Bewbies
    With your mom
    Could always put bedliner on the inside of your car. Not only will it reduce sound, but it will make it waterproof...:ph34r:
  7. newb
    newb phresh VIP
    Backwoods Northwest
    I heard of usin that DIY bed liner, but I never knew if it actually worked or not.
  8. George777
    With your mom
    I'm sure it would take a little prepping (cleaning, removal of seats, tracks, carpet, etc.), but I dont' think it would be much more than dynomat.
  9. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    My brother works in a customs shop and he dynomats cars. People come in and drop $1000 to have their car done, but it's wonders for the sound system, and I assume it works just as well for outside noise.
  10. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I doubt dynamat would help with outside noise, especially noise coming through the windows. IMO, your best bet is to have your car stripped of all it's weather stripping and redone with the newer, better quality stuff they put on newer cars like the vw's, audi's, bmw's, ect...
  11. daveholiday
    daveholiday Do work
    And again, open your wallet up.
  12. nootrac22
    exeter pa
    how bout ear plugs?? cheaper then dynomat and you get the same relative effect.
  13. BoostedHatch
    actually its a proven fact that it helps outside noise and you would put it where ever the most noise is coming from and in ur doors do not put on the firewall.just put it behind panels and stuff like that.
  14. phyregod
    phyregod !!YTINASNI
    Central Texas
    pull out the dash, seats, carpet, and headliner. Dynamat everything in sight.
    I had a 92 civic that had that done to it, even inside the rear fenders. sounded almost cadillac like rolling down the road.
  15. ghsbaseball91
    ghsbaseball91 New Member
    Catawba, Virginia
    i like the earplugs idea, but if you wanted to still have music..wear them big ass head phones plugged into an oldschool portable CD player
  16. newb
    newb phresh VIP
    Backwoods Northwest
    Shit if your on a budget just go to Good Will and pick up some old throw rugs. Then go get some spray adhesive. Then all you gotta do is cut the rugs to the shape you need, spray em down and stick em on. Just like Dynamat, but cheaper.
    1 person likes this.
  17. watkinscrx89
    watkinscrx89 New Member
    E-TOWN
    quiet
    If you need to go cheap get carpet pad and put under your carpet.That dynomat is heavy. "just a thought"
  18. |Chaz|
    |Chaz| Well-Known Member VIP
    Ahaha, that'd be so ghetto.
  19. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Its not necessary to dynamat your whole car, do behind the door panels, the trunk/hatch and it should be fine. Expandable foam goes a long way too.
  20. phyregod
    phyregod !!YTINASNI
    Central Texas
    Do you want a quiet cruiser or a quick car that is loud as hell? There are choices to be made here.
    Also, Close up the body gaps as much as possible. Adjust the doors, fender, and hood and get those gaps as small as possible. Less wind noise. And be sure to slap a big chunk of dynamat on the strut towers.. lots of road noise to be absorbed there.
