Make Me An Offer....
Discussion in 'Members' Lounge' started by jeffie7, Mar 22, 2003.
  1. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    I would put this under the for sale part of the site but its not really forsale just wondering what I can get for it not just what I could get but what you guys would pay
    then again if the right offer comes in I might take it
    95 civic dx 159497 miles on the car 4247 miles on the engine yes 4247 only
    Strut Tower Brace
    Lowered 2 1/4 inches
    Progress Camber Kit
    Aftermarket Struts
    Konig Wheels with Kumho Tires
    3 Auto Meter Gauge Pods on the left piller
    3 2 5/8" Gauges Tach, Boost, Oil Pressure
    MSD 6A Ignition Amplifier
    MSD Blaster SS Coil
    MSD plug wires
    NGK R Plugs
    Apex-I Turbo Timer
    Apex-I AVC-R
    Upgraded Motor Mount Inserts
    Upgraded SI Radiator
    MSD Plug Wires
    88-91 JDM B16A
    91 Integra LS Trans
    Full custom 3" from turbo back with 3" tip
    3"" downpipe
    ACT Street/Racing Clutch 6 puck disk
    Hondata ECU with boost upgrade
    4 440CC RC Injectors
    Spearco Intercooler
    T3/T4 Turbo
    HKS Blow Off Valve
    Tial WasteGate
    Open Dump Tube
    Crower Titanium Retainers
    Crower Dual Valve Springs
    ARP Head Studs
    JE Custom Type R Pistons
    JE Piston Rings
    Eagle Connecting Rods
    Darton Ductile Iron Sleeves
    Pro Drive Oil Pump Gears
    GSR Oil Pump/Housing
    car was built/tuned by www.tempestracing.com and engine swap was done by fred ellis www.crxguru.com
    used CTX 10w30 for the first 1000 miles then switched to Moble 1 15w50 synth oil and have used honda oil filters from the start
    I just replaced the master and slave clutch clys
    car would come with the stock D15B7 motor/trans as with ECU and injectors
    also a stock exhaust with stock cat
    2nd downpipe "for use with stock exhaust "smog reasons"
    I also have a 2nd set of wheels that came with the car some dinky 13" but good for winters
    just wondering what I could get
    car is in Maryland
  2. Tonyd0821
    Tonyd0821 Banned
    a 96 civc ex from where i live (down by newport beach)
    on Ebay, went for 7500.00
    he had a gsr conversion and a shitload of mods.
    btw, its nice to see someone with an engine swap that does more to it than just bolt ons....
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If I had money and was looking for a new car,hmmm...$8,000-$9,000 :unsure:
  4. BodyDroppedNikes
    caught in a mosh...
    a car as "old" as that with those miles (on the car, not engine) a bank will not finance $8-9k for it...unless you pay cash for it (but who has that much cash laying around???). you MAY be able to get $5k tops (but i see you have way more into it). banks dont look at whats done to the car, they look at the car itself and determine the value based on shape of the car and miles. my dad was a VP for a bank and he told me thats how they did it.
  5. ScrapinSi
    ScrapinSi Senior Member
    My buddy sold his GSR Turbo 93 Civic EX with lots of mods for $6k....
  6. xj0hnx
    C.C.TX.
    Believe me I know this :D ,it was hypothetical,but I'm not sure about the civilian world,but here in the military we can get signature loans based on how long you have been in the service and how long you have left.That's how I got the loan for my car now and the money for the swap and excess goodies.
  7. jeffie7
    Maryland
    try having a bank give you a loan for a 2000SI with extra money so you can fully build the motor and turbo it they wont do that either
    thats the problem with "hobbies" you wont get anything back out of them unless its old trains, guns, coins...
    bottom line is if some ones looking to build a honda for speed they can either
    A. buy a car 2-5K then sink 10 into it and still have stuff on the list of things to buy
    B, buy one fully built and done right to start with for 13-15K
    I wish I went with the later....
    the going rate in maryland for an engine swap is 3500-5500 "parts and labor" turbo kits if done right installed will run you 4500-5500 "counting install and tuning" if none then make that 2500-3000 bucks
    so thats 7500 bucks right there then you need to resleeve it 1000-1500 bucks
    then pistons/rods 800 bucks rings 80-100 bucks
    labor to put it in 750 bucks
    then exhaust 500 bucks and custom dp 300-400 bucks
    see my point?
    I very much doubt I would sell my car just becuase its a blast and Im only a set of injectors and manifold away from 350-450WHP
    but if I could do it again I would pay 15K bucks for my car as it is then to build it over again
    keeping in mind I paid 6800 for the car to start with before mods
    I know people with older 240Zs worth 10K plus to bad you could only get a loan for 2K if that...
    on paper its not worth much to bad some of them have supra TT engines as with skyline engines and GNX engines.... the point is who cares what banks say becuase in that case my cars worth 3500-4500
    ending quote... hobbies are for one thing and that is to burn holes in wallets
  8. pissedoffsol
    you could get about 8 grand for it. if you hold out, 10k is possible.... but its going to take a while to sell it.
    what are you looking at getting?
  9. jeffie7
    Maryland
    just wondering thats all but I have heard of cars going for 12-14K but its all in the right person at the right time
    bottom line if some one knows what it really cost to do things right then chances are it will go for more
    how much did you pay for your setup brian? VS building it yourself
    same thing goes for that
    always cheaper to buy what some one else has done VS building it from the ground up
    Jeff
  10. pissedoffsol
    im not a good example. i got my motor from a guy who needed cash fast, to pay his court fines :p
    what i got, was worth:
    gsr swap - 3000
    IB build - 4000
    b16 head work - 2000
    misc shit - 1000
    i paid 4200 for it with 4k on it.
  11. jeffie7
    Maryland
    no it is a good example it just shows that if you buy it predone its alot cheaper then doing it yourself
    on AVG what do you think a fully built honda would cost you? Im talking buying a Chassis not in need of paint also having the insides being very clean and a motor that could hold 500WHP what do you think it would cost?
    and don't use your B hook ups=) damn you and your friends but on avg for the AVG hondaswap member what it would cost
    Jeff
  12. pissedoffsol
    avg cost to build a 500 whp car? 500 bucks. n20 owns you
  13. Havok
    Havok Senior Member
    Florida
    lol, shit, get some nitro methane, much cheaper than 500 bucks. Just make sure you race for more than the value of your car :)
  14. jeffie7
    Maryland
    no really now..... to build a car that will hold up and last more then 5K miles in other words drive it everyday to work and back
  15. pissedoffsol
    5k miles? thats not too bad. id say 5 grand just in work.
    to last 20-50k miles, i'd say 10k just in work
  16. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    I'll give you fiii dolla!
