Making a patch cable CAT5 5e 6
Discussion in 'Members' Lounge' started by reckedracing, May 29, 2018.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    I know some of you guys do this type of stuff.
    I am needing to run some cable at home for home office use and have some CAT5 spooled wire, and just ordered a crimp tool and RJ45 connectors from amazon.
    Any pointers I should watch out for? I know about the pairings and braiding and use the same color codes on both ends etc. Back up plan is a 50 or 100 ft pre-made cable which are already both on hand. I just don't want to drill half inch holes in my house when a much smaller hole with do if I can get these ends on the cable myself.
    Back story, OL works in health care and is being moved to 100% WAH. Work is putting in a dedicated business class cable line. WIFI is a strict no-no apparently.
    More back story. The electrician that wired our office screwed the pooch by using the A scheme on one end of the cables and the B scheme on the other end of the cables. The day the office moved in we ended up having to pay the IT people to speed test and redo all the cables. So I know enough to ask you guys ahead of time.
  2. TurboMirage
    Briansol and reckedracing like this.
  3. reckedracing
    NY
    ahhhh good pointer there, thanks for the tip
  4. reikoshea
    Dallas, TX
    Your first 10 or so cables are gonna suck, so practice a few times on a short piece that you can cut down and retry a few times until you get a feel for it.
    Don't strip the wires before hand.
    Make sure the connector is facing the right way when you try and line up the wires (I always do tab up, some folks always do tab down, just be consistent to make sure the order is correct).
    reckedracing likes this.
  5. TurboMirage
    i always do tab down, cuz i can see them slide into the 8 little conduits.
  6. Briansol
    :ph34r:
    jamesA and TurboMirage like this.
  7. jamesA
    Newer switches it won't matter if it's a crossover.
  8. jamesA
    I have had better luck running from non-pre-made spools, and doing jacks/plates. There is always the chance of snagging and ripping off the tabs making them almost useless... ESPECIALLY if the walls are insulated.
    D16Civic likes this.
  9. D16Civic
    D16Civic Matt VIP
    Chesterfield Twp, MI
    I agree. And if aesthetics matter the plates are the way to go. I hate to just drill a big hole and stuff a fitting through. Drives me crazy
  10. reckedracing
    NY
    So I ended up having a spool of 5e in the basement at the office from our 2005-2007 ish build out.
    Ordered the crimp tool and ends from amazon with a tester.
    Cut off a couple 4-6 inch pieces to give it a practice run. Did 2 fittings on one piece and it tested ok so I just went for it.
    Tried to drill a 1/4" hole but the drill bit wasn't long enough to make it through the baseboard, hardwood and subfloor.
    Ended up having to use the 3/8" bit anyway as it was longer and long enough. Ran the wire, installed ends, tested with tester, and then hooked it up.
    All in all I consider it a success. Went a lot smoother than I figured it would.
    I wish I had a longer 1/4" drill bit but I don't care about the baseboard as its trash anyway.
    If it were new baseboard and drywall I would have considered a plate for aesthetics, but chances are the room will be redone in a few years anyway.
    Thanks for all the pointers and tips. I use the B scheme and tab down.
