manifold swap??
Discussion in 'Engine Building' started by skrewthesyst3m, Apr 7, 2004.
  1. skrewthesyst3m
    skrewthesyst3m Junior Member
    i was wondering, i have a 94 ls integra. can i take the manifold, injectors, and throtle from a gsr and swap in to my b18b1? any gains or loss's. help me...
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    hmmm
    interesting theory
    i don't have answers for you
    but check the cc rate for the injectors... and the mm measurments for the throttle body, that will be a good start...
    gonna have to wait for someone else's response regarding the intake and runners...
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    the injectors would be fine, but the GSR manifold with the dual stage runners/butterfly's is no good. Very bad design from honda. You would probably lose HP with that mani.
    matt
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    not to mention it wont even bolt up to the LS head. also, i think gsr and ls injectors are the same.
  5. E_SolSi
    the injectors are the same
    the manifold will not bolt up to the head
    both throttle bodies are 60mm
    sell the GSR manifold, injectors, TB, and then buy a skunk2 manifold for the B18B1
  6. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :withstupid: if you were to make the GSR manifold work, you'd still have to find a way to actuate the IAB
