Manual Conversion Question
Discussion in 'Prelude' started by Acepryus, Dec 10, 2006.
  1. Acepryus
    Acepryus New Member
    Missouri
    I'm looking at a 93 Lude Auto to start a project with. I was wondering what all is involved in doing a manual swap. Is the firewall punched the same as the manual?
  2. stlpsycho138
    stlpsycho138 Junior
    The LOU!
    it should be.... the only hard thing is the wiring.
  3. Nickg4c
    Nickg4c Member
    Gilbert, Az
    Correct me if I'm wrong but it sounds like you haven't bought the car yet. In wich case I would just find one that is already a manual.
    Doing the manual swap isn't all that difficult, its just time consuming. Their are a few people on here who have done them, myself included, so we can help you with any problems you run into.
    To answer about the firewall, I doubt its punched. I had to drill the hole out, but honda outlined it already. Mine was done on an accord, but the preludes are very similiar in this aspect. Let me know if you want more info, because I found a write up that I can send you.
  4. stlpsycho138
    stlpsycho138 Junior
    The LOU!
    on some of the hondas that i have encountered, the holes you need are just plugged with rubber grommets, or something equivelant to that. but it may also be outlined. either way, it's still not hard.
