Manual Trans fluid
Discussion in 'HYBRID -> EG-EK / DC' started by 92egSi, Jan 30, 2009.
  1. 92egSi
    92egSi I need DOHC VTEC
    I am about to install a ob1 gsr. I would like to drain the trans fluid and replace it with new fluid. I was told in my sohc to use castrol gtx. Would I use this in the gsr trans as well?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes
  3. eg6sir
  4. killercannible
    killercannible Senior Member
    Also try Gm synchromesh, its great for older trannies that have seen better days.
  5. 92egSi
    I think I'm going to go with the honda MTF. Cant go wrong with using honda fluid in honda transmissions. Thanks for the input guys! I appreciate your help.
  6. Rejecked
    Rejecked New Member
    martin, GA.
    I use Pennzoil Synchromesh Fluid. That and occasionally some Lucas if something seems off.
  7. eg6sir
    you only need to use Synchromesh fluid if you're getting minor grinds.. if the tranny is fine, i see no reason to spend $11 a quart on synchromesh
  8. 92egSi
    Maybe the syncromesh would help prevent having grinds in the first place.
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Regular Honda MTF has sychromesh/friction additives already.
