Map; Resistor Box Reusable From Obd0 Honda?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by afterburners, Feb 13, 2003.
  1. afterburners
    afterburners Junior Member
    Is the stock 88-91 MAP sensor, resistor box for the injectors, and all the other vacuum lines okay to use with the new h22a swap? I hope member "ima2nr" can answer this question? All others are welcome for there input!
    swap is h22a into a 88si honda prelude :blink:
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I know you can reuse the vacuum lines, but I think you'll need a new resistor box since you're switching OBD's. But yeah, ima2nr could probably shed a little more light. :)
