Map sensor help.
nq8s
I have a obd1 wireharness with a 01 LS motor, LS intake manifold and a GSR throttle body swapped into my EG6.
I keep getting code 10, 3, and 5.
I've tried changing my map sensor, switching ecu's checking my wiring and I still get those codes. I am running a 94-95 p75 auto ecu.
Now my question is does the map sensor wiring go stright to the ecu? pin d19/d20/etc? map ground/map 5v/and?
Do the wires tap into anything or those 3 wires go stright to the ecu in the locations given in the pinout listing on the reference page of hondaswap. Does anyone have a picture of their map sensor and what wire color order it is in from right to left and what color wire goes to what pinout on the ecu?
Thanks,
