map sensor help
Discussion in 'ECU's, Electronics, and Tuning' started by webhead, Jun 15, 2013.
  1. webhead
    webhead New Member
    hello to all can anyone help.
    i have stuck a b16a2 into a ej2 d15b7. im using the b16 engine harness, engine came out del sol or crx cant remember .
    all was going well when i relised the map sensor is on the plenum of the d15.
    i know you can get a bulkhead 1 , but does anyone know how to wire it up to a p30 ecu?
    and i know a vacuum goes to the throttle body at front but i think theres 2 tubes that come off the map sensor , anyone know where that would go cheers.
    ohh and does anyone know what color wire the knock sensor is at the ecu on a obd1 harness thanks , im trying to plug things into the engine harness wires that are there already to make it look better.
