MAP sensor on 89' crx w/ b18b swap????
Discussion in 'ECU's, Electronics, and Tuning' started by b18vtecrx, Jan 2, 2004.
  1. b18vtecrx
    b18vtecrx Senior Member
    i just need to know if i only need to extend the wires from the map sensor then run them to the MAP on the TB and i need to know if i only need to extend the wires for the coolant sensor to the new place of the b18b one. thnx for any help and pix would make this much easier on me. please help me out -mike
  2. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    3 wires for MAP...
    *snip*
    3 approx 12" pieces of wire
    *solder*
    *wrap with elec tape or heatshink*
    done.
    as for coolant temp, similar deal :)
