MAP Sensor Question
Discussion in 'HYBRID -> ED-EF / DA' started by kylelohrenz, Apr 7, 2007.
  1. kylelohrenz
    kylelohrenz Junior Member
    Hey Guys, My question involves my 88 DX with an OBD1 B16. Can I use my map sensor from the 88 civic for the OBD1 engine or are they different. The engine never had one on the manifold in the first place. Thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if i remeber right you can but im not for sure,
  3. 89hatchd15b
    89hatchd15b now its a 91
    Acton, CA
    There is a map sensor on the firewall in your 88dx. You can use either map sensor. they work the same
  4. kylelohrenz
    Thanks for the info! Kinda figured but did not know if there was a difference.
