map sensor
Discussion in 'HYBRID -> EG-EK / DC' started by sbcsam, Nov 30, 2003.
  1. sbcsam
    sbcsam Junior Member
    I just finished installing my b16 in my 95 hb,and i noticed that the engine doesn't have a map sensor. So now i have there wires that i can use for my vtec and knock,or should i look for a throttle body that has a map sensor,or do the b16asir2
    don't come with a map sensor
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yes they come with a MAP, it may have been an external that fell off.
  3. sbcsam
    no it didn't come with a map sensor.i used my stock harness and i had an extra plug which is the one for the map sensor.and the harness that can with the b16 dint' have a plug for the map sensor.
  4. xj0hnx
    C.C.TX.
    B16A's come with MAP's, I'm not guessing, they do. On the top of your throttle body, there is going to be a small metal tube if you had an external, or a hole for an internal.
    Here, maybe this will help...
  5. 92civicb18b1
    92civicb18b1 The Trisexual
    Well that help me, I have an external. Now I dont have to buy one.
