Accordturbo94
Hey im worried about putting a T-fitting in my map sensor hole in the throttle in case it has a vaccum leak! is it possible or safe to relocate the MAP to a diffrent vaccuum spot?? Its a turbo accord! with the check valves in the line..... i know some hondas you dont need to do check valves but this one you must!
