I dont see it?Quoted post[/post]]
Behold ! New Blog with new items installed !
Haven't wired them totally yet. Since I lack a rear defroster, I was gonna use that switch. I need to pull the positives from the defroster out of the relay (And ultimately, out of the harness) . But dude, I hooked them to the 14v bench supply and they are OBFUCKINNOXIOUS dude. Bright as hell and seen from any angle.Quoted post[/post]]
Nice! Good to see my fogs go to a good home. Do they work well?
Quoted post[/post]]
nice steve, but you forgot to post about your new rear garnish
Quoted post[/post]]
Quoted post[/post]]
The back of the car was against the garage door. In the daytime, more pics will be taken of the whole shibang. I'm surprised I got a pic of the interior - it's so dark that you can drop a lit flashlight and not be able to find it.
Also, the lights were installed into the lower grille trim. They fit like a fuckin dream. The little notch at the bottom of the housing rests on the lower grille bar, and they are shallow mounted, flush to the grille. Behind it the IC that I got from ef9civicgen should sandwich behind them very well.
The car will be ... densely packed. I already have to relocate my trunk appliances to make way for the battery box.
Quoted post[/post]]
well, you could have had a sub box
Quoted post[/post]]
Quoted post[/post]]
Why wouldn't you keep it for the CRX ?
Quoted post[/post]]
$250 for one, new. Circuit city.
the CRX should actually recieve the Basslink3. It's a flat unit, single 12" with two 10" radiators and the built-in amp. It's like $20 more, but it lies flat.
Quoted post[/post]]
KEAPS IT REAL y0!
also, did Clayton show you the cool intakes the 1st gens have?
