Mass air flow sensor
b18civic1013
I have a 96 honda civic with a b18b1 swap and i was wondering if it had a mass air flow sensor, and if it does where is it at? will it make my car run worse with out it?
no mass air flow sensor (maf) it would be on the intake if it did. but if it was suppose to have one it would ran bad without it.
All Honda motors, short of the K20Z have the speed-density (D-Jetro) air metering system. No MAF, only a MAP.
You could put a MAF on it and run a different engine management system if you really wanted to... some people do that to play around a bit.
