Mass Air Flow Sensor?
Discussion in 'Civic and CRX - EW' started by gdc2000, Apr 3, 2007.
  1. gdc2000
    gdc2000 Noob
    Winder GA
    Just got my engine back together and noticed I have no mass air flow sensor. Any particular one better then the other? I have only minor mods but my head has bigger valves in it and just got redone as well as a new head gasket,timing belt, alternator,starter,rear main seal, water pump etc.
    I dont know if one of the "performance" ones are better or if I should just go with stock.
    Its a '88 CRX si.
    Thanks
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    Your crx is not a mass air flow metered engine. It uses a map sensor and a speed density system.
  3. gdc2000
    gdc2000 Noob
    Winder GA
    OK I will take another look in the book. I have no idea what its called then.
  4. gdc2000
    gdc2000 Noob
    Winder GA
    I can't find the name of that thing anywhere cause it has a different model listed in the book. If I remember right it is about the size of a dime or a nickel and it plugs into the intake tube and has a little pigtail that plugs into the (MAP?)sensor. Not really sure. I know when it is not installed the car gets really confused and does not know how much fuel to use so it wont idle. I have went to a couple of places and they are trying to sell me a Intake charge temp. sensor. I dont know if that is it or not. I found the map sensor last night on the firewall and nothing is plugged into it so I am assuming what I need plugs up into it.
    This is the last piece I need to get this thing back on the road and if anybody can help me out that would much appreciated. Thanks.
  5. boostin4fun
    Omaha
    There should be a vacumm line running to the map sensor on the firewall from the intake manifold. Also there should be a electrical connector plugged into it. The sensor in your intake tube is most like the intake charge temp sensor.
  6. gdc2000
    gdc2000 Noob
    Winder GA
    Ok thanks for the info man. That vacuum tube is what I am missing as well as the intake charge temp sensor but if I remember right I never had that other sensor installed. Really appreciate the help. Time to go get some new vacuum lines and I should be good to go.
    Also I need to move the battery because the intake is in the way. Any brand of relocation kit better then the other? I was wanting a sealed system since it will be inside the car, thanks.
  7. boostin4fun
    Omaha
    Im sure any relocation kit is as good as the other. If im not mistaken I think summitt racing makes a decent kit for a reasonable price.
  8. gdc2000
    gdc2000 Noob
    Winder GA
    Thanks for all your help man. The car is up and running like a champ. The throttle response is amazing and its got a lot better get up and go with the head work done. The idle problem was the map sensor. The thing was like $228 so I went to the junk yard and spent $5 on the thing lol. Also after bolting on the intake I forgot about the 10mm hose between the valve cover and the pipe itself and it helped out a bit also.
    Once again thanks for all your help and a buddy actually had one of the summit kits so I am going to get it tomorrow and put it together this weekend.
    I have concluded that the people at Gwinnett Place Honda in Duluth GA are just as noob as I am.^_^
  9. boostin4fun
    Omaha
    Yeah most mechanics deal with bitch repair work. They are not always the best, but they think they are because there so called certified!
  10. boostin4fun
    Omaha
    Glad to hear everything worked out for you.
