Master Rebuild Kits For Dx Crx
doofnoil
Does anyone know where I can get the necessary rebuild kits to totally rebuild my dx crx engine? I also need a transmission rebuild kit.
What the hell for, you can get a D16A for the price of a rebuild kit for that worthless engine. It has throttle body injecton, pretty much worthless for performance.
Honda dealership. I would just get a d16a6 or a zc and call it a day, unless you are doing a rebuild with higher compression pistons in that block. You can get the zc or 88-89 integra pistons in there to bump up the compression a little.
I'm keeping the block and head for the r/s ratio, putting in aftermarket pistons and rods, block posting, throwing in an si cam and doing an mpfi swap so that I can go turbo later on.
