Matching obd1/2 to there injectors/distributor?
phlare
can i run an obd1 ecu with an obd2 distributor and injectors? im getting both responses... "yes they must match" and "no as long as there all plugged in"
but you need to fix your injector wiring with your obd1 wiring!
Can you tell me a place where the fitting is describe!
i need to plug a rs 99 into my civic vx hb 92!!!
