5 bolt flanges do not flow as well as the 4 bolt flange IIRC. If you read the description of the Turbonetics "ball bearing" turbo, it says that in this case they are used to strengthen the thrust bearing. A true dual ball bearing turbo has a floating CHRA. This all just means that that is not a true Garrett GT series competitor.
The Garrett may not spool 1500 RPM earlier, but on general the initial spool up is "only" 10%, 15% at most quicker. The biggest difference is spool recovery between shifts--a dual ball bearing turbo is really amazing.
