Maxima driveline noise
Discussion in 'Other Vehicle Discussions' started by 99sidude, Oct 11, 2010.
  1. 99sidude
    Ohio
    I've got a 99' maxima 5 speed, with just over 110k. It has been on Eibach springs since the beginning. I've got this gradually worsening noise/vibration. Think of the sound a bowling ball makes on a lane as it rolls. Now take that rolling noise and pulsate it. The pulse increase with vehicle speed, and it will come and go, it isn't constant. The problem is more noticeable at low speeds and when I first start driving. I can't detect anything over 50mph.
    It increases with vehicle speed - which makes me think it is either a CV joint, diff output bearing, or wheel bearing.
    Upon first looking into it, I found grease slathered all over my pass wheel well. DING DING DING - bad pass. CV. So I take this past Saturday and replace it (total PITA btw). Wasn't fun replacing heavy, greasy parts with one arm in a cast. Get it all back together and the noise is still there. WTF?
    Jack it up again and check the FR brakes and bearings. The hubs spin freely with no odd noises when the calipers are off. Then I find that the driver side slider pins are seized. That HAS to be it right? It took a torch to get one unstuck, but I get that fixed. Still making noise[​IMG]
    -So, what are your guesses? The driver side CV is an 8 month old rebuilt unit. I noticed a pin hole in the boot and grease spread in a concentric circle. Could that be toast already?
    -Could be the diff bearings (common problem on maximas) - however the trans doesn't leak a drop.
    -Wheel bearings? 110k seems a little early for that right? Hubs seem to spin nicely.
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Sounds like a wheel bearing. It's never too early for a wheel bearing to fail. 110k is a shitload of miles on an old maxima.
  3. haao13
    haao13 New Member
    PA
    :werd:
  4. civicious
    Houston, TX
    ahhhh, Nissan....the Ford of Japan.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  6. 99sidude
    Ohio
    Hey look at that! No I didn't get around to checking it yet. I will today though.
  7. 99sidude
    Ohio
    Well, I swapped on my set of winters and the noise is still there:(. I think next I'll be replacing the drivers side CV. It's only 8 months old, but the boot is already leaking. Has a lifetime warranty, so it's a free fix, and will need to be fixed down the road.
  8. 99sidude
    Ohio
    Update:
    Right side wheel bearing is toast. I jacked up each front corner and drove the wheels. When I did the right side it replicated the sound I've been hearing. There's a brand new cv on that side and I just checked the brakes. Gotta be the wheel bearing.
  9. civicious
    Houston, TX
  10. 99sidude
    Ohio
    You win. Pressed in a new set of timken's and the noise is gone
