May seem easy to you...
Discussion in 'Engine Building' started by Slimtadder, Dec 21, 2002.
  1. Slimtadder
    Slimtadder Senior Member
    Lake Havasu City, AZ.
    How the fuck do you get the crankshaft pulley off and also the alternator pulley off. I don't want to resort to using a plasma cutter on them.
    Thanks
  2. pissedoffsol
  3. E_SolSi
    *good* impact gun.... and it will still most likely take a while
  4. Slimtadder
    Tried that anything else?
  5. E_SolSi
    get the car up as high as you can and use a large half inch drive ratchet w/ an impact socket and about a 4 foot bar to torque it off with
  6. E_SolSi
    those are the only two ways i have done it .. i think the dealership has a special tool they use, but i doubt they will let you use/rent/buy it
  7. Slimtadder
    The motor's on a stand, I guess I will keep messing around with it.
    Thanks
  8. DazedCivic99
    DazedCivic99 Senior Member
    Florida
    slug hammer for added power with that torque, lol
  9. nestle_2000
    nestle_2000 Junior Member
    You can't get it with an impact gun? For your alternator, you can try heating up the nut with a propane torch. Keep the flame on it until it's searing hot, then take an impact gun to it. The heat should expand the nut enough to peel it off. The crank pulley bolt, well...i have no other ideas. Make sure the compressor is at full charge, and there's no extentions or adaptors for your socket set. Just gun and socket...nothing else.
  10. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    heating it up worked for me. but instead of the impact, i just stood on a breaker bar and it broke loose. and im only 165 lbs!
  11. Slimtadder
    I'll give it an honest try...
    Thanks
