May start all over...
Discussion in 'HYBRID -> EG-EK / DC' started by GoodSleeperRight, Sep 26, 2004.
  1. GoodSleeperRight
    GoodSleeperRight Member
    New York
    I think i might go civic type R motor into the 94 civic hatchback.Will it make it any easier then the GSR motor?I will have the complete swap from Hmotorsonline either way.So i will have the harness for either motor.Will wiring up vtec be the same or not with the differnt ecu's?
  2. BrowNKiD
    BrowNKiD Member
    Toronto, Ontario, Canada
    im not 100% sure but im pretty sure its the same amount of work... ctr motor i better than gsr but more expensive... and gsr is a good motor to all boost.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If you get a 94-95 GSR it's mostly plug and play.
    If you get a B16B the ECU and wiring harness won't work in you car (harness as wrong type, and backwards and ECU will need an adapter)
  4. GoodSleeperRight
    New York
    Hey thanks man thats all i needed to know...GSR it is B) Anyone with the power can now close this :D
    Hit me up on aol sometime aim name is GoodSleeperRight...Leave a PM and i will add you
